What exactly is recommended for starting a car that hasn't been started in 3 yrs.
Change oil, drain gas, change plugs, what else? How about lubing the cylinders somehow?
Car has a built fresh motor, afr 165s that have been worked, gt 40 lower, rap box upper, 24 lb injectors, 255 pump, bbk 75mm tb, bbk long tubes, msd cap and rotor, h pipe, flows, full length sub frames, I know it has springs shocks struts upper and lower control arms but I have to check the receipts that came with it, alumin drive shaft, 410s, 3 gauge pillar, phantom gauges, monster tach with shift light, electric fan with controller, cd player, 9.9 out of 10 original black interior, new tires, fair pony's and more that I just don't know the specs on till I pull the valve cover or check the receipts like the roller rockers, push rods, forged pistons, girdle,etc. Will be for sale soon
Cool. Well hopefully its in the big ass pile of receipts.
Also, the car has afr heads and 24lb injectors but has a stock mass air. How is this thing running and how much better would it run with a bigger one?
If you have an old distributor pull everything off the top. They work great with a drill attached as an oil priming tool.
