Does anyone know the pressure that the TV cable needs to be set at and the process? I've adjusted it by feel but it's still a little off. Also, does anyone know if there were any minor differences in an '89 Bronco throttle body and a '96 F150 as far as the positioning for the TV and throttle cables? Thanks.
AOD TV pressure help
Here's all you need to know. Good luck.
FORD AOD Automatic Overdrive BLOCK TYPE-TV CABLE ADJUSTMENT IMPORTANT: The AOD transmission may feel like it is shifting at the right time when the TV cable is actually way off! The transmission will work for a while and then FAIL! It is critical that you learn to set the TV exactly like this...
Thanks for the links, the pressures are what I was needing. Part of my problem is when I had a guy do my exhaust he did a half ass job and bent the bracket the TV cable goes to. I thought I put it back to where it belonged but I guess I'll see once I get a gauge on it.
