F250 transmission
  • F250 transmission
    Well I think I just blew up my tranny after picking my son up from daycare this evening. I rolled out at about half throttle from a stop when I felt and heard a loud bang, I was able to coast to a side street where I tried to use all forward gears, reverse and then I tried 4 wheel drive before I shut it down. The drive shaft is still intact, so I'm guessing I snapped something in the transmission. It's a stock 2000 F250 with 225k miles and there hasn't been any signs of the tranny or anything else acting up, but I guess I was about due for an expensive repair on this thing.
    I'm real leery about putting my vehicles in the shop, but I'm pretty certain this is going to be beyond my skill level of repair. Does anybody have a solid recommendation for diesel/tranny shops around DFW? I live in Keller, but I'll consider taking it anywhere in the area for a reputable shop.
    TIA,
    John
    mikes trick shift, pm me if youd like the #
      Auto or manual?
        Originally posted by thesource View Post
        Auto or manual?
        It's an auto. It does have a faint 'tranny whine' now, even in park.
          More likely the tranfer case I would bet if you heard a loud pop
            my family has used AAAA transmission in fw for years
            07 f250-family truckster
            08 Denali -baby hauler
            52 f1-rust bucket
            05 Jeep tj. Buggy
            livin the double-wide dream
              Even if its the transfer case, going into 2wd should lock the front and rear section of it together and it should move. I'm no expert on automatics but it sounds like something in the front like the input shaft or convertor if it won't move at all.
                Thanks for the reference. It's being towed to Mike's shop as we speak. I did a little research online last night and based on that it sounds like the mechanical diode blew apart, which means it will need to be completely rebuilt. I feel pretty good about taking it to Mike's after talking to him on the phone... he's going to do a few upgrades including a custom built torque converter with a billet front cover that he's building.
                I'll update my thread when I get the truck back.
                John
                  John
                  yes sir, glad to hear. Mike is a great guy to deal with.
                    I wanted to give an update to the outcome of my transmission problem. I took my truck to Mike's Trick Shift and he said the converter came apart and took out the input shaft. So he did a total rebuild including a custom torque converter. This thing shifts GREAT, it's better than when the truck was new. It shift's smooth at low rpm's and firm when I lay into it.
                    Mike is a great guy to work with and I highly recommend him for any of your auto tranny needs.
