Stock 302 heads cam intake builds
  • Stock 302 heads cam intake builds
    Tossing around some ideas on top end parts for the coupe.
    What have you guys had? How well did they run? What power/torque did they make? And how was the power band?
    I wanting some aluminum heads, an intake and maybe a cam.
    Thanks.
    I'm wanting 300+ rwhp. If possible, most builds I see are 280-290rwhp
    About time u decide to stop jacking around with that stock shit
      AFR 165s, ported cobra intake, stock cam.
      Full time ninja editor.
        Mike,
        How about adding a TMS Turbo Kit. Call Clint and ask him what it made on another customers "bone stock" car.
        I am doing a mild 306, GT40P Heads, Holley or Trickflow Intake, B Cam, and TMS Turbo Kit. Clint feels that my car will make every bit of 475 - 500 HP and be very mildly mannered on the street.
        Robert
          Originally posted by 89FivePointOh View Post
          Mike,
          Robert
          My worries with that is the stoke block going out.
          Ive seen stock bottom ends make 560+ rwhp and hold fine. Just iffy
            300 rwhp is easy. Back in the late 90's I made somewhere around 350 to 360 rwhp with the following top end parts. Car was a 5 speed 89 hatch and ran consistent mid 11's on slicks and skinnies.
            GT40 U/L intake - lower was ported
            World Products Windsor Sr. aluminum heads 2.02/1.60. Some port work.
            Comp XE282HR-12
            70mm TB
            77mm Pro-M
            Compression was about 9.5 to 1
            Hell, I'm pretty sure I still have all these parts laying around minus the throttle body. I could make someone a good deal. I don't need them any more.
              I wouldnt mind getting around 300rwhp n/a and then use a 150 shot.
                Comp XE282HR-12
                70mm TB
                77mm Pro-M
                What all do you still have?
                  Comp XE282HR-12
                  70mm TB
                  77mm Pro-M
                  Forgot to mention. I used the same topend on a 331 stroker, combined with a Vortech B-trim and the car made mid 500's to the rear. And, ran mid 10's at almost 130mph in the 1/4.
                    You gotta be kidding me.
                      and the motor will go BOOM! All it takes is one thing to fail on N20 that you forgot about and your motor is toast!
                      I have seen every safety device installed on a N20 car and the motor threw a rod out the side because of all the added torque coming off the line...
                      Not a good idea with a "stock" block Mike
                        I've still have the intake, heads and I think that same cam. I would have to dig it out and see for sure. I've either got the cam that I mentioned above or a Comp NX282HR-14. The NX cam is more suited for nitous or a blower but, it would still work fine for an N/A combo. I sold one of them, just don't remember which one.
                        I've also still got the Pro-M mass air too. However, it is setup for 75lb. injectors. It would have to be recalibrated.
                          I sent you a PM!
                            Mike, I have a pretty good hook up on brand new heads. My motor isat truestreet being assembled and when I get the numbers I'll let you know how they did.
                              What's to kid about?
