A quick fix would be to use some teflon tape, then bleeding your brakes. The proper fix will be to replace the line and proportioning valve.
Leaks happen.
I'll just snag the prop valve and line off of my 89.
I had this problem last winter the fluid would go low and I noticed the leak, no problems during the summer and now since it's cooled off its back at it.
If it's the proportioning valve, it would be a good time to upgrade it to an adjustable unit. If you ever went to 4wd, it's really nice to have.
x2. Pull to prop valve, use a couple unions, then put an adjustable in. Probably take ya all of an hour maybe. Depending on if you have to do any cut and flare.
