Engine Gurus - Need some thoughts and opinions
  • Engine Gurus - Need some thoughts and opinions
    So I am thinking it is time to start doing some engine mods. Already have the suspension, rear end, and just recently switched out the T5 with a TKO-600 road race transmission. Specs on the motor are as follows:
    302, stock heads, and stock internals as far as I know. BBK cold air, stock MAF, Edelbrock RPM 2 with 70mm throttle body. Going from memory, when I had it tuned, the car did around 232hp/289tq on the dyno at HPP.
    Here are a couple options I am looking at doing with the motor:
    Option 1 - Heads Only
    AFR 165s with 1.550 215@1.950 Valve springs, ARP 7/16 rocker studs, Crower 1.6 and 1.7 roller rockers, and stud girdle bars, 30lbs injectors and 70-80mm MAF.
    Option 2 - Heads and Cam
    All the above, plus a cam. The cam I am looking at is the B303 (284° 284° 0.480" 0.480")
    Basically, looking for opinions on the setup. I want to stay with basic stuff right now so I am not having to worry about piston to valve clearance issues, but still squeeze some more HP out of the motor before the bottom end blows up and without dumping a ton of cash.
    So the options are heads or heads and cam? If that's the case I'd say heads and cam
      Heads and cam
      Vortex rear stand $75
      8.8 410s. $50
      **SKAGG NASTY**
      1990 Foxbody GT for that ass
      11 4 door
      13 FX2 White 5.0
        Afr is a good choice. But I would look at a comp or Anderson cam instead of b-cam.
        07 GT500
        05 SRT10
        88 turbocoupe T-bird
        93 Cobra
        86 coupe
        Ducati 848
          Stud girdles are a waste of money on that setup, the springs to run a B cam are puny.
            It's very possible to make good power with a stock cam, and if you are looking to retain the best drivability possible I can understand it. Here's a cool article I remember from a while back....
            However, that said....if you are tearing it down that far you might as well take the extra time for the balancer, waterpump, and front cover R&R.
            As said above though....I would also advise against a B cam....it's just simply old technology (what ~20-years now?)....there are a lot better options out there for your time and money....however as opposed to just taking a guess, I'd get on the horn with AFR and have them make a recomendation that is best paired with their 165 heads.
            70' Chevelle RagTop
            (Forever Under Construction)
              this
              1993 Vibrant Red Cobra #1741.
                anderson nt1 cam and afr165's netted 301/322 to the wheels on a 30 over 302 with cobra intake and 70mm tb and 76mm maf
                  According to that article link, they made 278hp with an intake/carb swap on an otherwise stock 302? Added heads and headers for 400hp? I don't see it.
                    And I would choose TW170's over the 165's. More potential to grow and allows you to run a larger cam(more lift).
                      I picked them up used and all that hardware came with the heads.
                      See above.
                        I appreciate the info so far fellas. I am looking to get as much info / first hand experience as possible.
                        I just picked the B cam due to not having to clearance the pistons. I will look around at different options.
                        I did send an email to AFR to see what they would recommend.
                        Really, the plan is to get as much as I can out of this motor with a little coin, then when it goes boom......Thats when the money starts flowing into a stroker for the car.
                        This car is strictly a track car. No street at all.
                        I would post a pic but I am at work and the internet sucks out here. Almost feels like dial up.
                        Here is a link to the build thread.
                        http://www.dfwmustangs.net/forums/showthread.php?t=8900
                          Said this before, but that car is sooooooo sick!!!
                          Ded
                            I had a stock shortblock carb'd 306 with some oooooold ass aluminum gt40 heads and a comp 282 cam. 420 flywheel horse, ran 7.80s in a 3350lb car.
                            8.8 410s. $50
                            **SKAGG NASTY**
                            11 4 door
                            13 FX2 White 5.0
                              420 flywheel is not 400 at the wheels. Is the article talking flywheel or rear wheels? I didn't see which. You had aftermarket heads and they used stock E7's.
