Originally posted by 91CoupeMike
Rear end gear ratios: 3.73 3.90 4.10
Originally posted by jnobles06 View Postx2. i had 4.10's in my 95 cobra, then with in a week i switched to 3.73's you'll be cruising about 2200-2400 at 70mph. i think i'd like 3.55's even better.
I would say that it depends on if you prefer 1/8 or 1/4. For the 1/8th I would go with 3.73's. If you run 1/4 mile with 3.73 gears you will be at the very high end of the rpm in 3rd gear when you hit the traps and if you shift into 4th you will slow down. I went with 4.10's so I could shift before the traps and still be in my power range.1991 Mustang GT - 127,000 miles, original owner
1996 Mustang GT - 84,000 miles, all original but 3.90 gears
2012 BOSS Laguna Seca #493
Originally posted by MrGT5oh View PostI would say that it depends on if you prefer 1/8 or 1/4. For the 1/8th I would go with 3.73's. If you run 1/4 mile with 3.73 gears you will be at the very high end of the rpm in 3rd gear when you hit the traps and if you shift into 4th you will slow down. I went with 4.10's so I could shift before the traps and still be in my power range.
Sent from the last stall on the lefthttp://dfwdirtriders.com/ New Website for the off road peeps
Originally posted by JC316 View PostAt 70MPH, my Super Coupe is cruising 2400RPM with 3.27's. Damned M5R2 and it's .75 OD gear.
Originally posted by SNEAKY View PostHe Is already at 5500 in 3rd in the 1/8. I am pretty sure h could not make it another 660' before tagging the rev limiter. On another note, shifting to 4th should not slow you down.
Originally posted by jnobles06 View Postmy girls gti runs 2800 at 70 which is stupid high, but i am used to driving v8's so maybe it's not.
that's what i was thinking too. i am at the top of third gear about to shift into fourth in the 1/8 miles with 3.73's
Originally posted by Lucky 13 View PostI have 4.10s and have to shift to fourth before the end of an 8th mile with my H/C/I setup. not as bad on the freeway as some people make it out to be. I can cruise at 60 all day long at 2000 rpm.
You have a extra steep 5th or you just going 50?
Sent from the last stall on the left1991 Mustang GT - 127,000 miles, original owner
Go 3:55's Homer, no cam, no heads, your just wasting gas with 3:73's or higher on a stock 5.0...Originally posted by SilverbackLook all you want, she can't find anyone else who treats her as bad as I do, and I keep her self esteem so low, she wouldn't think twice about going anywhere else.
