Looking though parts lists, I just need to confirm some things before I make the plunge. Obviously I'll need rotors, calipers and pads. Hubs are the same. Only thing I've got a question on is if I'll need to change the brackets, or if the GTs will work. Should be pretty straight forward, unless you guys can tell me about any surprises I haven't anticipated. Looks like the master cylinder is the same.
99+ GT front Cobra brake conversion
Originally posted by talisman View PostLooking though parts lists, I just need to confirm some things before I make the plunge. Obviously I'll need rotors, calipers and pads. Hubs are the same. Only thing I've got a question on is if I'll need to change the brackets, or if the GTs will work. Should be pretty straight forward, unless you guys can tell me about any surprises I haven't anticipated. Looks like the master cylinder is the same.
Brackets are different. Are you trying to get the calipers from autozone/o'rileys?
Originally posted by talisman View PostDid some calling around. Brackets are obsolete through Ford.
Yep.
07 GT500
05 SRT10
88 turbocoupe T-bird
93 Cobra
86 coupe
Ducati 848
Originally posted by mk5.0 View Post50 resto has a kit
http://www.latemodelrestoration.com/...nt-Caliper-Kit
Jesus fucking Christ, I can get the calipers for $60 each, I'm not spending that much on this shit!
Here are the PN for the calipers with the bracket.
LEFT:18-B4654
RIGHT: 18-B4655
http://www.oreillyauto.com/site/c/de...yword=18-b4654
not sure if you can still get them, but you work at a parts store so maybe you can find them07 GT500
05 SRT10
93 Cobra
86 coupe
Ducati 848
looks like summit might have them too
http://www.summitracing.com/parts/AAZ-18B4654/07 GT500
05 SRT10
93 Cobra
86 coupe
Ducati 848
Originally posted by mk5.0 View PostHere are the PN for the calipers with the bracket.
LEFT:18-B4654
RIGHT: 18-B4655
Already worked that angle. Ridiculously expensive.
what year brackets will you need? 03-04? Or will earlier work
99 being parted out in austin
