93 coupe ac blows ice cold out the vents but when you put the car under acceleration the air quits blowing out vents and starts blowing out the defrost and the car then runs sluggish. Turn the ac off, car runs fine. Wtf
a/c / vaccume issue?
If you don't find a leak on the plastic line on the firewall (mentioned above), check around your vacuum tree on the drivers side of the firewall...you've got some hard lines on that side too...all of those hard plastic lines are known for becoming brittle over time.70' Chevelle RagTop
(Forever Under Construction)
