would i gain anything by running 2 fuel lines (one to each fuel rail) from the fuel tank? currently i have areomotive a1000 fuel pump running one line into a y-block then to the fuel rails, how much hp could this support? thinking about adding either a supercharger or a turbo and would like to know if my current set up is sufficient to support the power or do i need another pump and fuel line (one for each fuel rail)? TIA
fuel system question
Depending on what size your lines are now will depend on the responses on if you have adequate fuel supply.
I run a -10an (overkill) from the tank to the front of the car where it splits from a Y-block -8an to the rails. Rails feed the regulator and a single line (-8an) runs back to the tank.
My system is set up to support 800+hp of E85 fuel on a turbo car and is plenty for what I need. YRMVFuck you. We're going to Costco.
Originally posted by kbscobravert View PostDepending on what size your lines are now will depend on the responses on if you have adequate fuel supply.
Originally posted by bonnie&clyde View Posti have a -8 from the tank all the way up to the rails and a -6 back to the tankFuck you. We're going to Costco.
