Fuel pump for boost
  • Fuel pump for boost
    ANYONE USE OF THESE YET FOR A MILD SUPERCHARGE BOOST BUILD....FUEL SIDE USING 42S, CUSTOM TUNE, AND A VORTECH UNIT WITH 7-8 LB PULLEY.
    ITS FOLLOWS THE SAME AS THE VORTECH BOOST A PUMP....
    A 255lph will be fine for your combo
    '93 Cobra-Coyote Powered
    '13 Dodge Cummins
    '14 Rubicon X
      got that already just dont want to go lean when tuning and getting ready for dd.
        I have a 255 in tank and a Vortech T-Rex inline. I am running 42lb injectors and an S Trim with 12 lbs of boost. No issues with fuel.
          I had one of these http://www.summitracing.com/search/B.../?autoview=SKU ran it for about 5 years with 42's. carboned the crap out of my imrc's but the car never ran lean.
            the vortech pump is equal in flow rate has this pump....just trying to make it easy without having to wire extra pump
              my novi setup made 10 psi and with a 255 intank and 42# injectors never gave any problems kept a constant watch on a/f and at wot was a tad rich
                255 is plenty of pump
                  I run this walbro 255, but added a KB BAP, which was probably overkill, especially on the stock pulley.
                    well i have the walbro 255 in tank....put it in there when the stock pump took a dump....guy at dallas mustang told me might as upgraded it rather put a stock one in and then have to upgrade later.
                      There are several 255 pumps.
                      Walbro GSS 340 is what you need.
                      Aeromotive makes a 340 lph drop in now also.
