How complicated is it, and what do I need to pull apart to get to it? Top goes down like a champ, but is going back up very slow. I'm sure it probably hasn't been touched since it was new, and I'd like to try this before forking out $200 on a new motor. Thanks guys.
Adding fluid to a vert top motor on a 99 GT
Originally posted by talisman View PostHow complicated is it, and what do I need to pull apart to get to it? Top goes down like a champ, but is going back up very slow. I'm sure it probably hasn't been touched since it was new, and I'd like to try this before forking out $200 on a new motor. Thanks guys.
Originally posted by talisman View PostAfter 13 years none of the fluid would have been used up?
Originally posted by Whiteboy View PostIts not sealed douche bag. The pump has a sep hole. Why dont you learn a little about what your'e talking about before you post. btw go fuck yourself
The only benefit to changing the fluid to ATF would be that ATF might be thinner than the hydraulic fluid that is in it, helping the pump. Or if there is trash from the pump going out, flushing might help, but in the end, if the pump is going out, its going out."If I asked people what they wanted, they would have said faster horses." - Henry Ford
You guys don't think that after 12 years some of that fluid hasn't broken down, or been "used up?"
Jeremy, have you had this problem and solved it before with that solution? This car is just a beater, I don't want to put a lot of money into it. However, I do want to the top to work since that is the primary reason I bought it, and it is now nice enough outside to put it down again.
Have u checked the motor to see if it is low on fluid? When mine is low the I can hear,the motor but the top won't raise. I have a leak in one of the rams. I have to add atf about every 15 times I drop the top. The fluid leaks into the quater panel so it is not noticable. To check, pull the panel in the trunk. Pump has a plastic plug. Pull it out and add fluid till it runs out. I heat the plug in microvave to get it in easier.
Originally posted by talisman View PostYou guys don't think that after 12 years some of that fluid hasn't broken down, or been "used up?"
