VW Passat brakes
  • VW Passat brakes
    Anyone know if a 2004 Passat's front and rear disk brakes free floating rotors or hub... Got my brother coming over to fix his grinding brakes. Thanks!
    Oh, and was there some special dang tool needed for the VW's??
      They free float.
      No special tools are needed.
      You do need a rear caliper retract tool. You can rent a generic one at autozone or o reilly.
      All disc brake jobs are easy.
        Awesome, thanks. I know on newer VW they have some "tri-square" tool for the front calipers.
          They free float.
          Also, a retract tool, is this to retract the caliper piston? If so, I have done this before with a C-clamp on an old Blazer I had.
            that should work
              Thanks gumby!
                Unless it's like retracting calipers on '94 and up stangs, they actually screw in. If that is the case you can rent the "special tool" at a parts store.
                '93 Cobra-Coyote Powered
                '13 Dodge Cummins
                '14 Rubicon X
                  You need the tool for the back Tan but how many miles are on it ? I bet the rears are still good .
                  Big Rooster Racing
                    Originally posted by 80coupe View Post
                    that should work
                    No it wont, they have to twist in.
                    I've done a passat before, that's the only special tool needed.
                      OK jim, ill rent that part then. Hopefully it'll be nice outside.
                        I have the one for the Ford and if its the same one you can use it . It is a universal tool .
                        Big Rooster Racing
                          Mike, what year was the passat u did? Parts dealer is saying it might have electronic sensors on the front pads... You rmember that?
                            it was just a wild guess
                              Aight Jim, I might give u a ring tomorrow for it. Err, I mean later today...
