305 Running rough at low idle??
  • 305 Running rough at low idle??
    This all just started happening outta the blue. I drove it sunday morning without any problems. Tuesday I start it up and it started to run fine till i got half-way down the street and it started running rough and died. I started it back up gave it a couple of revs, cause i thought there was a hiccup or something. Started driving again and as soon as i took a turn it died again. So i started it back up, gave it some gas and it acted fine until i let off. Does not wanna run at a certain idle. I thought it might be plugs or something. But they look clean. So maybe junk in the carb? Or distributer problem?? Or maybe its because i dont have an egr valve?? Not sure my truck has an egr vavle, because i can not find one. I have an aftermarket manifold and carb. ITs the edelbrock eps intake manifold and 650cfm carb. Also have aftermarket headers. So how can i fix this?? Heres a video of what its doing just sitting in the driveway.
    GOPR0198 by larrychance88
    Is the exhaust very rich? Could be the carb or a misfire. Are the wires/dist in good shape?
      Vacuum leak possibly?
        What is funny, is that my bone stock 85 c10 was doing the exact same thing off and on. I thought it was the carb for the longest time. turned out to be a misfire due to wires arcing.
          Good...Topic
          Wow...That good. Thanks for sharing.
            Originally posted by aektsuke View Post
            wow...that good. Thanks for sharing.
            wtf?
              Originally posted by Jimbo View Post
              wtf?
              Gay ?
                Have you noticed a change in your brake pedal?
                I agree with the possibility of a vacuum leak.
                  Did u fix the gas leak/vacuum leak chance
                    Here's what you need to do..... Buy a Ford, instead of having a Ford racing steering wheel cover on your chevy truck AND stop posting Chevy chiiit on a Ford site
                      Fucking newb dumb asses.....
                        Shut up bitch, i dont have that on there anymore and you fucking know it. This site is for everything.
                          Well i let it sit last night, and i started it up today and its running fine. Is puffing out blue smoke, which i know that means my seals need to be replaced.
                            Ahahah
