I took my car out last Friday for the first time in a month or so, and its making a banging noise (almost like a rod knocking) in first gear and reverse. It's definatley coming from the transmission, I tried cycling the transbrake a switch a few time (I haven't used the transbrake since I had Mikes Trick Shift go through the transmisison 2 years ago). I've put less than 500 miles on the transmission since it was gone through and only raced it once at the Cruise a year ago (2 passes and I footbraked it instead of using the transbrake). Anyone have any ideas? Is it worth dropping the pan to see if anything looks up or should I just pull it out? I haven't tried adjusting the band yet, but the locknut was tight so I doubt if its backed out.
I
I
