Originally posted by streetscraper1
Best Battery?
Originally posted by Capngizmo View PostDuralast gold or if you have a bit more $ optimas yellow topWhos your Daddy?
Originally posted by kingjason View PostOptima is not the same company it was a few years ago. I believe they have been outsourced or something to that affect.
optimas are not the same anymore.
for me i go to autozone and buy the gold and try to get a top and side post battery.
for me i go to autozone and buy the gold and try to get a top and side post battery.Whos your Daddy?
Originally posted by 71chevellejohn View PostThey are distributed by interstate in some areas.
<-- has an interstate distributor across the street from my office.
Optimas, walmart, interstate, duralast are all made by johnson controls, that's why they are ditributed together. I believe motorcrafts is also a johnson product.
On most ford eec cars the computers drwas upwards of .5 ma for 45 min after the car shuts off. If you want to know for sure pull the negative battery cable close all doors, turn off lights etc. And put volt meter inline between negative post and terminal and set to amp reading. Monitor over night. Anything less than half a milli amp is in spec. Any more and it will cause premature battery failure.89 dove grey lx, turbo blowthrough
Batteries go through a chemical process as the electrons flow through the electrolyte/acid solution and between the plates. Due to the acid content an overstressed battery begins to build lead sulfate on the plates. As you charge the battery th lead sulfate converts back to its normal state. When a battery is repeatedly drained and charged it makes it harder for this process to reverse. Some of the lead sulfate remains on the plates increasing the resistance to electrical current flow thus lowering you cranking amp output. In the same manner some of it shluffs off and settels to the bottom. When enough builds up that it bridges between two cells(plates) it shorts out the battery.89 dove grey lx, turbo blowthrough
