I've got a 90 mustang with the stock 75amp altenator. The battery has been moved to the trunk and I have a 10 gauge wire running from the altenator to the battery side of the solenoid. How can I check that the altenator is charging the battery correctly?
I also have a CSR electric water pump and A1000 fuel pump and stock pcm. I am about to hook up an electric fan as well. Will the stock altenator cover all of this or do I need to upgrade and if I do need to upgrade what should I go with?
