Just bought a new radiator cap and thermostat. Going to try those along with an air deflector and a good bleeding of the system and see where that gets me. If that doesn't work I can get a replacement LT1 radiator for $90 shipped from Amazon.
LSx coupe running too hot w/AC on. Any tips?
I had this exact problem on my 96 mustang later in it's life. Temps fine until you turn on the AC in traffic and then it would steadily climb. I sold the car to my friend who replaced the radiator and that seemed to solve the problem."Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man." - Thomas Jefferson, 1776
So I took a good look at the car tonight and think I might have figured out at least part of my problem. The belt wrap on the water pump is probably allowing the waterpump to slip and not spin at full speed. If I grab the waterpump pulley I can spin it pretty easily since the belt just goes under the pulley and only has a very small contact patch.
So I looked through my parts bin and found an idler pulley that will work with my f-body alternator bracket. I'll have to shim it out a little and get a new belt otherwise it looks like it should work perfect. This setup will increase the contact patch significantly. I took a piece of wire and soldered it together to figure out the length of the belt I need and have ordered it. So hopefully between a new thermo/radiator cap/and rerouted belt I should be running cooler.
Here is the new belt routing:
Originally posted by UserX View PostThat should make a big difference, good luck.
How much resistance do waterpumps have on them with the motor running anyway? I know some guys pick up 8-10rwhp when they go to an electric pump so I guess they have some resistance behind them.
Dville, did this fix it?
Curious minds want to know.sigpic18 F150 Supercrew - daily
86 SVO - Sold
'03 F150 Supercrew - Sold
01 TJ - new toy - Sold
65 F100 (460 + C6) - Sold
Originally posted by Lason View PostHoly crap!! Yeah I would venture to say that the belt wrap is most if not all of your problem.
Still haven't pulled the trigger on the front air deflector, car is so low as it is and I think I'll be dragging that thing on everything so hopefully this will work.
Planning to take the coupe out to my FIL's shop in Weatherford this weekend to modify the exhaust (going to add in 2 3.5" ultraflow mufflers to hopefully quiet it down a lot). It will be the longest trip I've taken in the coupe as of yet so hopefully all goes well. I think I am going to borrow the wells off of the Cobra to drive there on (don't want to ruin the ET Streets for nothing), but the reduced RPM's from the 28's will be missed on the highway.
Got the new belt on, took it for a little cruise. I replaced the IAT sensor that was residing in the MAF and replaced it with a thermistor and mounted it in the front bumper. This threw my tune way off since the car was seeing 130-150* heat soaked IAT temps and now see's 95-100* (actual temp) IAT's. So I drove it around for 20-30 minutes messing with the tune and leaning it out (lower IAT's = more fuel). I didn't run the a/c though since I want to put the gauges on it and see what my high-side pressure looks like before I go running it and damaging the compressor or something.
Anyways, ran between 198-205 the entire time. Granted this was at like 8pm so the temps were not at their peak, but this is definitely an improvement. Going to run by Buick355's tomorrow night and see get the a/c pressure sorted out then on Saturday I am driving it to Weatherford (about 40 miles), so that should give me a good indication of if it is fixed or not.
