Small block ford ?s
  • #31
    Originally posted by Txstang1 View Post
    My 383w has run a best of 11.01 on motor (6.9 1/8) and has squeaked into the 9's on a 200 shot. Runs on pump gas and can be driven anywhere.
    Last time I saw it did it also have A/C ?
    • #32
      Originally posted by Doug Hatton View Post
      I'm thinking about building a top-fuel funny car... anyone have any pointers?
      Doug lets build a 400+ci. motor with 2 116mm turbos
      • #33
        Aftermarket block, 3.25 stroke, 5.4 rod, 4.125 bore big cam afr 205, super victor lower intake spyder elbow 1 7/8 headers 3" exhaust with 12:1 solid roller .625 lift 245 ish 250 ish duration 110... Something similar to that setup should make close to 500 rwhp an twist to 8k all day..
        • #34
          these guys have it all figured out for you.........
          pinto gt with wood trim
          • #35
            http://cgi.ebay.com/ebaymotors/ROUSH...#ht_2222wt_782
            I saw a 427 Yates Heads engine for sale in the classifieds here..
            A NASCAR engine would be badass, but here's my question. They wrap up to 10k rpm right? How impractical is that for drag racing? Just correct that with steep ass gears? 4.56+?
            • #36
              9.5 deck, 427 makes 675 on pump gas. The last thing you need a is a used nascar motor
              Or an 8.2 deck makes 575 on pump gas, get your wallet out is all you need.
              • #37
                6.33 or a 6.50 at martinsville. you really need to educate yourself on how hp is made. HP doesn't just magically happen at an rpm you pick. Hp happens due to cylinder head flow only, cubic inches then decides how early (rpm wise) that power can be made. more cubes, lower rpm target power can be achieved. The term torque and hp are pointless as they both happen together, or actually one because of the other. A cup, busch, truck engine will barely clear 500 ft. lbs. ever in it's total range, yet at 9400 they make close to 900 hp..........
                they turn 500" pro stock engines north of 10K..........so what's your point about drag racing?
                • #38
                  351w hyd roller 10.5:1 compression and get the lightest internal forged components, rhs mediums sized heads, gt40 intake, custom grind cam, aluminum flywheel and driveshaft. could be had for $3500 especially if you find used heads/ driveshaft/ and flywheel.
                  • #39
                    True, but 350rwhp isn't shit. If I can't beat 2012 cars that are stock why spend money on it?
                    The other way would build a stock shortblock 351w and do h/c/I. But I see that as wasted money because it will still be slow.
                    I want to run in the 5s at some time in my life.
                    Lol, try running 8's first.
                    350rwhp would blow your mind at your current level. A 351w/350rwhp fox is unable to beat '12 cars? How fast are these new cars you have to beat?
                    Wasted money? I don't see bottom sevens on a stock windsor block as slow or waste.
                    Here, just buy this guys setup: http://www.yellowbullet.com/forum/sh...d.php?t=389234
                    • #40
                      Are you trying to make a point about the torque? Those numbers are no where near your 500/600 numbers and its a 12 to 1, 408, with jr's.
                      Not to mention this:
                      • #41
                        Oh my little shit box 302 makes my little coupe keep up with heavier cars with a lot more power.
                        The only thing I hate is falling short on the big end due to lack of power. Falls on it's face after 5000rpm.. Having a power band of 2500-5000 isn't that awesome to me.
                        RPM's break things. I had a 308 that I used to spin to 7k regularly, with the cam and vic jr intake, thats where the power was. Tons of fun dropping it into second gear on the highway. Now I have a split 302 block.
                        • #42
                          You underestimate the capabilities of a torquey little small block in a light-ass coupe.
                          haha, that he does!
                          www.LockoutSupplements.com
                          discount code = dfwmustangs
                          • #43
                            8.2 dart block stroked to 357 some good heads, custom solid roller & good intake.12.5 comp. 200shot. little coupe will roll out.
                            • #44
                              Yup, still a moron that doesn't know anything about cars or how they work.
                              • #45
                                Originally posted by GRAYHORSE View Post
                                haha, that he does!
                                Right. You were scooting with just, what, 360rwhp? I think that is the only time I actually saw your car at the track (don't get to go much).
                                I ran the same 1/8th mile as my Z06 in my Mustang II (better 60ft and slower mph) when the Mustang was only putting 262 to the wheels and almost 300tq.
