Mass air meter question
  • Mass air meter question
    I NOT SURE IF MY METER IS WORKING! MY CAR IS RUNNIG REALLY RICH AND I HAVE BEEN REPAIRING VACUUM LEAKS. I UNPLUGGED MY MASS AIR METER WHILE THE CAR WAS RUNNING AND IT DIDNT MISS A BEAT. IT RAN THE SAME. SHOULD THE CAR START TO STUMBLE AND HESITATE WHEN IT IS UNPLUGGED? I EVEN REVED IT UP AND IT STILL RAN LIKE IT WAS CONNECTED.
    WHY ARE YOU YELLING?
    Yes it should change pitch when the mass air is un-plugged
      Sorry i am at work! We have to type in caps if not the comp will not pic up the repair order!
        There is no change at all when my mass air meter is unplugged. Can it be tested with a volt meter? Or how can i test it?
          Have you pulled the diagnostic codes yet?
            No codes! I just swaped my comp 2 weeks ago to a (a9l). There has been no diff in the way it runs other than it running really rich. It went 9.0 in the 1/8. Mods-3:55 gears, full exhaust, pullies, rear upper and lower control arms, lowered, and a cobra upper/lower e CAM and a stock air box with a k&n. Ive just been trying to tighten it up and make it run good-dailey driver w/ air cond.
              No codes, or just no CEL on? If you are running rich then there will be codes.
                Have not pulled them yet! I am still working on pulling off all the smog crap, and fixing vacuum leaks. How do i test the meter? I would think the car would try to stall if it was unplugged????????????????
