I've had my 98 GT for over 5 years now. Bought it with the intention to build it up but ended up just using it as a beater. I've decided its time to start the build. Currently it has 138000 miles on it and is running great. I am going to have to replace the T45 transmission since it is showing its age. It currently has 2.73 gears which will be changed out to 3.73 or 4.10's possibly.
I've looked into doing either a PI swap with new cams like this (if you have a better suggestion on a head swap please let me know too) or find a 98 cobra motor with low miles and do a swap. My budget is around $6000 figured I would buy a used or new T56 or possible convert to an auto which leaves me around $3-4000 for the motor.
What I'm concerned about is will my stock bottom end handle the head swap or would I be better off finding a cobra motor. Or possibly buying a new 2v block and do the head swap on it.
Just for grins hear is a pic of my mustang and F150
I am leaning towards the PI swap since I would like to change the wheels and tires with the budget money too, but that can be done later if the motor is too old to handle the upgrade. I only plan to take it to the track occasionally, no hard use. And later on maybe put on some FI, but that is a big maybe since that is another $4-6000. Any help is appreciated.
Thanks, JRod
Thanks, JRod
