? about air press. sensing tires
  • ? about air press. sensing tires
    How do these things work? Is there something inside the tire that senses tire press.? Reason I ask is because my wife's '10 Volvo had a tire go completely flat while sitting at wrk. Volvo roadside assistance is going over to install spare. Can I take the tire to get repaired at any corner tire shop or does it need to be repaired at Volvo. I don't know what the damage is to the tire at this point.
    --carlos
    Cars with TPMS have pressure monitors either attached to the rim inside the tire or on the valve stem. Any tire place should be able to do it.
      well, it turns out the tire has a nail on the edge of the sidewall. I know this is not repairable. thanks
      --carlos
        At least make sure they have a modern tire machine. The old shoe type are notorious for busting sensors and some cars that can be a 300-400.00 mistake.
        6-25-10 RIP Chloe Rene Daddy loves you always
        78 Suburban (slammed with LS in future)
        54 Olds 88 2dr HT
        12 Camaro SS convertible
          Not sure about Volvo. Ford's sensors are on a band around the rim and GM's are attached to the valve stem.
          If google is right, it looks like Volvo's are attached to the valve stem.
            would your guys trust Discount Tire? apparently, they are the only ones that can get me a pair of tires, same type, by tomorrow.
            --carlos
              Yes, they seem ok.
              86 SVO - Sold
              '03 F150 Supercrew - Sold
              01 TJ - new toy - Sold
              65 F100 (460 + C6) - Sold
                The only thing with discount, regarding your tpms, they try to push a "rebuild" kit. They push it as being necessary,when really its not unless you have a problem with it.
                  Wait a minute......
                  .....you mean to tell me that the TPMS sys has to be replaced?
                  sent from htc EVO, the iCrap killer.
                  --carlos
                    When I had new tires put on, we just pulled the sensor off the old valve stem and attached it to the the new stem.
                    Unless it's a battery or something like that - I'm not sure what the kit would include.
                      When you get a rebuild kit, you get a rubber grommet to seal the wheel/valve. You get a new valve core (which will corrode in time btw) and a new clamping nut and washer. If the nut/core does corrode then you will more than likely need a new sensor which are roughly around $80ea.
                        That's basically everything that came with the new valve stems. To me it wasn't a rebuild kit, it was just a new valve stem made for TPMS use. I guess for Discount Tire it is a marketing thing.
                          Had the new tires mounted and installed yesterday. Discount charged $7.99 per rebuild kit. I was telltale surprised it was that cheap, anytime I hear "rebuild," I get nervous.
                          --carlos
