It has the 4.6 motor. When you are crusing along, especially if you just try to give it a little gas ~1,800-2,000 RPMs, it'll start "cutting out". If you give it more gas to make it down shift and bring RPMs up it'll speed on up. No codes just rough running at part throttle.
I replaced the fuel filter and "repaired" the vacum hose that runs from the passenger valve cover to the back of the intake. Also it didn't start until a day or so after filling it up. I had them fill up with 93 oct at a busy gas station and put some Berryman's in the tank, just incase it's bad gas. It was still doing it after all that. I told him to run it for a day or so to help move the old gas out, was 1/4 tank when we started.
4 door
