just picked my car up. some of ya'll know from the other board the deals i had with the 5.0 and i finally got it back. it had the tap/ tick i am refering to and he said the rocker is bad and its ok to drive just nothing aggresive until i can get it fixed? is this right? no additional damage to be done? also how much labor am i looking at cause i dont know dick about motors. oh and what decides 1.6 or 1.7 being better over the other?
5.0 making tap/ tick sound driver side
Originally posted by BUFFALOHALTOM View Postjust picked my car up. some of ya'll know from the other board the deals i had with the 5.0 and i finally got it back. it had the tap/ tick i am refering to and he said the rocker is bad and its ok to drive just nothing aggresive until i can get it fixed? is this right? no additional damage to be done? also how much labor am i looking at cause i dont know dick about motors. oh and what decides 1.6 or 1.7 being better over the other?
Originally posted by ToRqUeTwIsTeR View PostMy suggestion is that if you don't know dick about motors then you need to sell your car. Another suggestion for you seeing that you probably won't take the afore mentioned advice is to go back with the 1.6:1 rockers. You probably do not know what cam is in the motor therefore going back with stock ratio will eliminate the valve to piston clearance question. Also, another suggestion is that I would go ahead and get a second opinion. It could be that you have a bad lifter. They are known to lose their prime over the years and need replacement. Rockers usually don't go bad unless they are broken and usually that means a bent pushrod and a trashed lifter.
do i need to go to a performance shop for this opinion. car is a performance car with heads and all but performance shops take forever and i rather steer clear if all possible
Originally posted by BUFFALOHALTOM View Postha i have too much into this car that i drove for the first time today and i bought it in august. deal i'll sell it but you have to buy my 01 vortech car also so i can do what i should of done and get a terminator...and actually i know exactly which cam is in the car cause i looked at it when my buddy pulled it out. it is a tfs stage 1 cam. i have the exact part number and can post a link to its specs if needed. its just in the other room.
There are a couple of guys here that are good mechanics and are fairly cheap. Turbostang; 2tnecpe; Jetfast50 to name a few. I don't know their schedules or if they would even be interested but if not I am sure there are others.
Originally posted by Sleeper View PostDo you want to learn how todo this shit?
I mean seriously swapping a damn 302 in a fox is about as easy as ordering drive thru at jitb.
Good luck with it.
Originally posted by bonnie&clyde View Postif its just the rocker just pull the valve covers off and switch the rockers, might also wanna check and make sure none of it broke off inside the covers... doesnt sound like that big of a job
Originally posted by bonnie&clyde View Postwell you can try it for yourself first, pull the valve cover off and if you see one laying on its side (like i did when i had a clicking noise) you can just swap it out, if that does not work take it to Gear Heads, they worked on mine and got me in an out in about a week
so 1st off great guys. good work. still recommend.
2ndly no thanks and i wont go into why.
ill give it a whirl i guess. i just want to use a regular shop if they are capable, if they are not i will go to a performance shop if i have to i guess
