Originally posted by garycrist
Could carbon build up on intake valves cause high leak-down numbers?
Originally posted by BP View PostYes carbon or other deposits building up can cause erratic leakdown numbers. Seafoam or GM's top end cleaner work great if used correctly and that is the problem. If a valve is bent you should be seeing 100% leakdown.
I have been digging around and it seems that some guys end up having what they say looks like over an 1/8th of an inch of carbon on the second intake valve while the other intake valve (the one not shrouded by the imrc plate) looks clean. I assume this is why they ditched the IMRC plates in 99.
Anyone know if it is worth it to ditch the plates? I see you can rig a relay to fool the computer, you can put springs on the actuator cables (too fool the computer), or you can get the computer tuned so you will not throw codes. I have heard though that you loose low end torque and that you might need to get it dyno tuned, if thats the case I'll just leave them.
Your thought of the wasted spark is right. Every coil is paired so if you had a dead coil on ay cyl1 then cyl6 would also be affected on its power stroke. If 6 is ok then you would look at plug wires/plugs.
When you say fluid what kind of fluid, was it gas oil or...
And on sea foam if your secondary intake valve can get carbon build up even though its not run hard enough to open the imrc then the sea foam should get there too.89 dove grey lx, turbo blowthrough
Originally posted by turbos66coupe View PostYour thought of the wasted spark is right. Every coil is paired so if you had a dead coil on ay cyl1 then cyl6 would also be affected on its power stroke. If 6 is ok then you would look at plug wires/plugs.
So hopefully the issue with the stutter will be solved by the new plugs/wires. The high leak down will hopefully be solved by cleaning up the intake valves as best as I can and then re-testing everything on a warm motor.
