I have one at work on a trash truck that has multiple codes and a check engine light. It has a 0555, 0556, and 0559.
555-Crankcase pressure - Data valid but above normal operating range. Moderatly sever level
556-Crankcase Pressure - Data Valid but Above Normal Operational Range - Most severe level
559-Injector Metering Rail 1 Pressure - Data Valid But Below Normal Operating Range- Moderately Severe Level
I can look up the diag tree but im wondering if anyone has run into this before? Im thinking it needs a lift pump but I dont have a lot of experience with diesel diagnostics.
