Speedometer gear for 3.73s!
  • Speedometer gear for 3.73s!
    I have the yellow tailshaft gear and I'm running the red speed gear. Because that is what latemodel said would be correct.
    I'm reading about 7-10 too fast.
    PM Jeremy (whiteboy) He will be able to help you out.
      You need to count the actual teeth.
      Different companies used different color codes.
        im running into that same problem with mine, i got my red gear from 50resto, i think we also need to change a gear in the actual speedometer but im not sure
        Originally posted by DOHCTR
          google the ford racing speedo gear chart
            I have tons of gears @ Dallas Mustang.
              I know, I just got one. lol
              04 GT
              91 LX
                Over the years ford changed colors on the gears.
                Assuming you have the 7 spline yellow gear on the tranny, youll need a 23 tooth cable gear for 3.73's.
                  If you have an 89 and prior T5 with the yellow 7 tooth drive gear you need the red 21 tooth driven gear. If you have the post 89 T5 with the green 8 tooth you are out of luck. The closest you will get is the 23 tooth white driven gear which is for a Jeep. The other bad news is that the 23 tooth gear doesn't mesh correctly and wears fast.
                    So I needed a 21 tooth gear not a 23?
                      Ford racing says otherwise, why's that?
                        That's for sure.
                        -Dustin
                        '94 Cobra
                        Coast High 408, AFR 205s,
                        1-3/4" BBK LTs, Tremec TKO,
                        ZA0 Tweecer Self Tune
                        09 F250 KR
                        10" lift, 38s
