2003 cobra water pumps??
  • 2003 cobra water pumps??
    Why is a 10th anv water pump taller?
    huh?
      I knew Autozones computers were wrong.
      Had a guy call in for one and it asked me, because the two had differant part numbers. ???
      Told the guy they looked differant and I wasn't sure why.
        They are wrong on a lot of stuff. Like u joints for fox bodies is one that comes to mind. And blower motor resistors for newer Chevy trucks.
        63 Fairlane
        Originally posted by forbes
        i call 1911 first then 911
          The u joints pulls 4cyl part numbers, well it used too. They fixed that one, pulls 4800 joints now, which I believe Is correct.
            There's a few parts on fox body's it'll ask if it's 4wd or not.
            Lol!
              there are 2 different w/p for a 4.6... either its a short snout or long..... cobras would be the short
                Also if you try to look up rear rotors on SN95 Mustang GT or V6, it will always ask if it's vented or solid rotor when vented only came on Cobras.
                63 Fairlane
                  Early 4.6 (non Pi) had the tall pump right?
                    Yep I have noticed that too.
                      the vented are larger dia too
