My 94 has issues with the tach jumping or bouncing. It does it at idle or driving when it jumps a slight jerk is felt. At wot it will detonate. Things ive checked and replaced. New fuel pump, new fuel filter, new coil, new battery, timing at 10', 93 octane. Could it be the mass air or TFI mod. sick of spending money and not getting anyplace. Any idea guys?
1994 mustang gt ignition issues.
Originally posted by Spector93 View PostMy 94 has issues with the tach jumping or bouncing. It does it at idle or driving when it jumps a slight jerk is felt. At wot it will detonate. Things ive checked and replaced. New fuel pump, new fuel filter, new coil, new battery, timing at 10', 93 octane. Could it be the mass air or TFI mod. sick of spending money and not getting anyplace. Any idea guys?
Try replacing the distributor if you have an extra one. The stator, which is the magnetic pickup, in the 94/95 distributors is very susceptible to heat. After a while the signal will go crazy, usually just before the sensor fails. Worst part of the cars. I started up my 95 GT the other day for the first time in a few months and it was doing the same shit with the tach. I am not sure if it is because it has been sitting or whatever but I figure I am going to need a distributor soon. Again (this would be my third). When the stator goes out completely, your TFI module is usually gone soon after and you end up replacing both parts.Originally posted by racrguyWhat's your beef with NPR, because their listeners are typically more informed than others?Originally posted by racrguyVoting is a constitutional right, overthrowing the government isn't.
Originally posted by Texasmustang View PostI have a good used 93 5.0 distributer if u need one. Pm me. Not sure if they are the same though2001 Ford Lightning Silver
1993 Mustang GT Silver Frost Titanium
1984 Bronco II 4X4 Silver & Red
Originally posted by Spector93 View PostSorry not that same at all the tfi module is external. Its mounted under the mass air meter.Originally posted by racrguyWhat's your beef with NPR, because their listeners are typically more informed than others?Originally posted by racrguyVoting is a constitutional right, overthrowing the government isn't.
Originally posted by Broncojohnny View PostTry replacing the distributor if you have an extra one. The stator, which is the magnetic pickup, in the 94/95 distributors is very susceptible to heat. After a while the signal will go crazy, usually just before the sensor fails. Worst part of the cars. I started up my 95 GT the other day for the first time in a few months and it was doing the same shit with the tach. I am not sure if it is because it has been sitting or whatever but I figure I am going to need a distributor soon. Again (this would be my third). When the stator goes out completely, your TFI module is usually gone soon after and you end up replacing both parts.
Originally posted by Vertnut View PostThat's what I was afraid of. Al, do you go to an after-market piece (MSD) or back to cheap stocker?2001 Ford Lightning Silver
