I had an old mustang guy tell me that it might help to run Rotella T in my 94 GT 5.0 for a little while. Since the car had sat for 6 years. He said it had much higher detergent levels than other oils, so it should help to eat away some of the gunk. Do yall think this is true? Do you think my high mileage motor that sat for 6 years will benefit from Rotella T? Or should I just run some random full Synthetic like Royal purple or AMSoil?
Rotella T for cleaning purposes?
Not really sure. I know it has more zinc in it than most other oils, about 1200 ppm if I remember right.
I run it in the 351w in my 68 because it has a flat tappet cam.68 Coupe- 351w, TFS heads, Comp XE284, 5 speed, Explorer 8.8, 4 Wheel Discs
63 Fairlane
Originally posted by forbesi call 1911 first then 911
Originally posted by Magnimike1 View PostJust fyi for those with flat tappets. The newer ci rating of Rotella will not have enough zinc and manganese to prolong a flat tappet cam. Run ZDDPlus or a Comp additive..68 Coupe- 351w, TFS heads, Comp XE284, 5 speed, Explorer 8.8, 4 Wheel Discs
63 Fairlane
