2011 5.0 #8 piston problems
    Originally posted by KungFuHamster View Post
    so pistons 1-7 are ok with going lean then...its just #8 that i have to worry about. well thats ok.
    I would imagine its a design issue. Lots of cars have cylinders that run hotter than others due to intake manifold/ head design.
      take the wire off 8, then hit it with 400 dry
      Texas Fastest Streetcar Shootout
      2008 Spring : 13.00 index Champion
      2008 Summer : Fastest Street Car Runner Up : 13.00 index Champion
      2008 Summer KODFWS : Runner Up
        i always thought cylinders 7&8 on the Ford motors ran hotter due to the coolant flow path....that was the case on the 03/04 Cobra motors, 2V motors and pushrod motors right?
        2011 Mustang GT
          Any 4 valve mod motor that didn't come from the factory with a supercharger. Terminators had the newer head castings, otherwise they burn valves in the rear cylinders eventually. Aviator, Navigator, Mach, Cobra, Mark, etc...
          SBCs are good about melting the #7 cylinder first due to engine cooling and the early LT1s (92-93) would melt the rear two from a poorly designed fuel rail that'd lean out the rear cylinders.
          Lots of cars have problems when you start modifying them when they aren't intended to be modified.
            lmao at --parts for (sail) <----- or is it sell, or is it sale, or cell
            http://i89.photobucket.com/albums/k2...g/P1010006.jpg
              Just get another 1-7 piston and put it in the #8 hole. Problem solved.
                I'm hearing about a lot of oil related failures on race tracks. Not putting one in my car now till someone figures out the mess.
