Quick Oil Pressure Question
  • Quick Oil Pressure Question
    what is the ideal oil pressure a fox body should run at once the car is warm and has been on the road for a while, what should it never drop below or never go above?
    Originally posted by DOHCTR
    I've always gone by half the RPM on a 302. 3000rpm, 15psi
      I have always gone by the 10lbs per 1k rpm . But , if my motor had under 20 at idle I would be changing the oil or looking for another problem . I think this rule was told to me by a chevy guy when I was a kid but I like to see 25-30 at idle when hot and 45 up when wound up . This is just what I like .
      Big Rooster Racing
        mines a little below half at idle to 3/4 on the gauge while driving.. so i guess im good!
        ازدهار رأسه برعشيت
          depends on how the bearing clearances are setup. It can live on as low as about 7psi per 1k rpm ROUGHLY. 10 is good rule of thumb
