Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Need help - electric fan install/conversion on a fox - DFW Mustangs
  • Need help - electric fan install/conversion on a fox
    Ok, here's where I'm at. I just bought a new alum radiator and this thing is huge, so big the the mark VIII elec fan I have will not fit.
    The fan is about 5.5 in deep and I only have 4.5 in of clearance between the rad and the water pulley. SO obviuosly this fan isnt going to work.
    I've done a little reading up on the net and it looks like some people are using the 95-2000 ford focus dual fan setup. They are supposed to be about 3.25-3.5 in deep, but I cant find any CFM specifications or anything other than than.
    What other options are available for my setup? its a 351w with a 2 1 1/4 in row radiator. THe focus fan is $338 from the ford house and I dont want to spend that kind of money unless I'm posistive it will do what i need.
    I want the MOST CFM that I cant fit in there, I want to be cool at the redlight when it 100 degrees out this summer.
    TIA, My car is sitting until I figure out a solution.
    Vortex rear stand $75
    8.8 410s. $50
    **SKAGG NASTY**
    1990 Foxbody GT for that ass
    11 4 door
    13 FX2 White 5.0
    3.8 taurus single from around a 93 model...trust me, they work. Theyre right up there with a mark but not as deep.
      Reverse polarity and use it as a pusher????
        They pull serious amperes at start up
          looking into now, thanks.
          ANyone know of a good website that has fan diminsions and CFM ratings ?
          8.8 410s. $50
          **SKAGG NASTY**
          11 4 door
          13 FX2 White 5.0
            I dont follow ?
            8.8 410s. $50
            **SKAGG NASTY**
            11 4 door
            13 FX2 White 5.0
              Originally posted by Txstang1 View Post
              I dont follow ?
              Placing it in front of the radiator instead of behind in a traditional fashion. Make the Fan push air threw radiator instead of pulling threw
                Performance cooling products for the automotive market. Flex-a-lite invented the Flex Fan and holds the patent for the first electric fan for the automotive aftermarket. The full product line now includes the patented Flex-a-fit aluminum radiators, electric fans, belt-driven fans, oil coolers, Mojave heaters and Flexite windows. And we proudly make our products in the U.S."
                  Does it look like this one?
                  8.8 410s. $50
                  **SKAGG NASTY**
                  11 4 door
                  13 FX2 White 5.0
                    that's what I thought you meant. Yea, that wont work because of the ac condensor. thanks though.
                    8.8 410s. $50
                    **SKAGG NASTY**
                    11 4 door
                    13 FX2 White 5.0
                      I'm gonna look around the shop I think I have one of those setups.
                        Nah its for a old Honda dual setup 12" and a 10"
                          thnaks for looking.
                          8.8 410s. $50
                          **SKAGG NASTY**
                          11 4 door
                          13 FX2 White 5.0
                            exactly. I usually get used ones for around 50
                              ok, thankks for the tip. I need to go look at one and make sure its not too deep.
                              8.8 410s. $50
                              **SKAGG NASTY**
                              11 4 door
                              13 FX2 White 5.0
