So i have been having some issues with my 89 stang that started suddenly. I have severe Ignition break up at idle and throught all RPMs. i have replaced the module, Distributer, pick-up, coil, and have even tried an msd ignition box. All have the same results. I tried to reset the timing and found that if i pulled the shout chip the car stop have the ignition break up. once inserted back in the problem starts again. I have no idea what the issue could be. I am thinking at this point it must be the ECU. Has anyone had this issue and can anyone help.
Help with a problem
Oh yeah i forgot to mention. Plugs, wires, cap, rotor, throttle body sensor, pro flow MAF, idle air valve, the works. new motor all new sensors. the wiring harness and the computer are the only things that have not changed.Nitrous is like a hot girl with an STD. You wanna hit it but your afraid of the consequences!
90 GT Carb 331, heads cam and a lot of bottle
95 Tbird SC forged 3.8, MPX supercharger, heads cam, and a little bottle
Try to unplug the mass air while its running and see if it smooths out . We had this problem with one of our cars and it would run ok with the mass air un pluged . Turns out it was a stuck injector and limp mode leaned it out enough to run . Swaped in some new injectors and the problem was solved . Thank God for the Greenbullit hotline !Big Rooster Racing
I think you still have a bad tfi or an improperly timed dist...Last edited by greenbullitt; 04-21-2011, 12:39 PM.Ring and pinion specialist
Have you verified the TDC mark on your balancer to make sure it true?Originally posted by stangstew View PostOh yeah i forgot to mention. Plugs, wires, cap, rotor, throttle body sensor, pro flow MAF, idle air valve, the works. new motor all new sensors. the wiring harness and the computer are the only things that have not changed.
yes I have check tdc twice. tried both firing orders and unpluged the mass air and made things worse. i can pull the shout chip so that the timing is locked out i put 6 degrees in it and it smooths out nd runs smoth through the rpms. pu the chip back i and the problem starts again. i took the shout from and friends car and it didn't help. I am fixing to light a match to this thing and just burn this f@%ker to the ground. also put in a new ingition switch.Nitrous is like a hot girl with an STD. You wanna hit it but your afraid of the consequences!
thanks for all the advice guys. I think that the ECU is bad. tried to check for codes and the ECU wont even talk to the obd1 scanner.Nitrous is like a hot girl with an STD. You wanna hit it but your afraid of the consequences!
ohh and sosoe i am thinking real hard about doing an LSsomething swapNitrous is like a hot girl with an STD. You wanna hit it but your afraid of the consequences!
i think i am having a retard moment. Dizzy and pip?Nitrous is like a hot girl with an STD. You wanna hit it but your afraid of the consequences!
the pip is the pickup inside the distributor. Ill put 20.00 on that being the problem.Replace with a used/new distributor, its less time consuming.Originally posted by stangstew View Posti think i am having a retard moment. Dizzy and pip?
edit! if the balancer is correct in referencing tdc and the dist is stabbed right, however, pip can cause what you describeLast edited by greenbullitt; 04-21-2011, 09:03 PM.Ring and pinion specialist
