Need help...AOD to T5 swap, car wont start.
  • Need help...AOD to T5 swap, car wont start.
    Hi everyone,
    I need help. I did a AOD to T5 swap on my 88 coupe and now it wont start.
    I swaped out the transmission harness from a 5 speed car and plugged it up into mine. I hooked up everything the way it should.
    The problem I have is that when I turn the key, the starter solenoid makes a noise but the car wont turn over(see video). I did install a new solenoid and had the battery tested to see if it was still good.
    what else could I check?
    When doing a T5 swap, what other wires need to be hooked up/bypassed to make it work?
    Thanks in advance
    3 words. nuetral safety switch
    Big Rooster Racing
      starter solenoid shouldn't make a peep if the NSS isn't closed
        Can you tell me what to do?
        I live in Haltom city if you wanted to come by and show me I'll pay you. lol
          That is not a problem with the neutral safety switch . You starter is not turning because there is not enough voltage or it could be stuck . It could also be a dirty or bad cable but was this the one that was on it before ? Is it the same starter or did you change it to a high torque (later model) starter ?
          Big Rooster Racing
            That first post was damitsteve under my sign-on so disregaurd .
            Big Rooster Racing
              I would come over now but my boy is in bed and my wife is working so I am stuck . I will pm you my # and try to walk you thru it .
              Big Rooster Racing
                oops!
                  LOL!!! DAMNITSTEVE! rofl.
