engine cooling issue - bad radiator?
    Sounds like a head gasket to me.
      I doubt it's a head gasket. I would buy a pressure tester and make sure there are no leaks. If you cant find any check the thermostat and then water pump.
      How many miles do you have in the truck? Any idea if the water pump has ever been replaced?
        thermostat? Heater core?
        sigpic🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄🐄
          All good info.
          Also try google, I came up with a few threads on a similar issue.
          (cute name for a forum "piloteers")
          Found a bit of a surprise today. Lately I've been smelling coolant on the outside of the Pilot once it warms up. Tonight I decided to have a peak under the hood. It appears the coolant (water) passage gasket, as Honda calls it, is leaking where it connects to the block :28:. I've been...
            how did the oil taste?
              I can't read the post but you didn't not mention the following in the first sentence
              Replace
              Thermostat
              Flush coolant
              Verify water pump is functional by bleeding the system as it warms up. Leave cap off the radiator to ensure waterpump is functional as air is bled by the thermostat opening.
              Don't over think the problem. Is coolant full and clean? Has thermostat been replaced?
                check to see if water is coming out the exhaust
                Vortex rear stand $75
                8.8 410s. $50
                **SKAGG NASTY**
                1990 Foxbody GT for that ass
                11 4 door
                13 FX2 White 5.0
                  What part of town are you in? If you are close to SMU I can swing by and put a pressure tester on the radiator and that will uncover any leaks very quickly.
                    i'll give ya 500 bux and a 6 pack for it
