HELP! I need help on my stats-PLEASE!
  • HELP! I need help on my stats-PLEASE!
    Someone please help me with these-
    Lower limit of .18
    Upper limit of .16
    This is the distribution.
    TIA!!
    Token Split Tail
    Lower limit of .18
    Upper limit of .16
    TIA!!
    hi!
      Lower limit of .18
      Upper limit of .16
      TIA!!
      Huh?
        Nm, we got it.
        Ugh-this class is teh DEVIL!
        Token Split Tail
          I love me some statistics.
            Care to explain?
              Originally posted by 3.90x3.62 View Post
              Care to explain?
              I wouldn't even know where to begin. LOL I'm just keeping my head above water. Thank God Chili has been helping me! Buut...he's at work and in a meeting so can someone explain this to me, please??!?
              9. What is the probability of obtaining three or fewer heads on eight tosses of a coin?
              This is the explanation and I have the answer, just need to understand the process....UGH.
              Use the normal curve to find the area to the left of the upper limit of 3 (3.5), which will include 3,2,1,0 heads
              Answer is .363
              Token Split Tail
                Answer is .363
                No, the answer is 42.
                  Not according to the answer sheet.
                  Token Split Tail
                    Fucking really? With all the god damn geniuses on this board, not ONE of you know how to do this??
                    Token Split Tail
                      Sorry, Statistics is not included in my DFWM support contract...
                      Hit me up when you want to know what a glide slope or radar side lobe is....
                        You need to find a z score for a binomial probability event. In this case n is 8, p and 1-p are each .5. Standard deviation comes in at sq root of expected value times p... 1.41. Z score is then (3.5 - 4) ÷ 1.4 which is negative .35. Look at the z table for that z score and you see that the corresponding probability is 36.3%.
                          You freaking ROCK! That's exactly what I needed. Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!
                          Token Split Tail
                            You can also treat it like a summation of probabilities; maybe not helpful in solving the problem, but why the answer is what it is:
                            Probability of getting:
                            3 out of 8 is .219 (56 of 256 permutations, not 3 out of 8)
                            2 out of 8 is .109 (28 of 256)
                            1 out of 8 is .031 (8 of 256)
                            0 out of 8 is .004 (1 of 256)
                            Added together is .363
                            The permutations are important because when you flip the coin 8 times, there are 8 ways, or opportunities, to only get one heads - 28 ways to get two, and so on.
                            -Henry David Thoreau
                              The only difference was that I have to subtract .5 from the z-score of -.35 in order to account for the upper limit. Z-score is .1368-.5= .3632.
                              Whew! Thanks for the help!
                              Token Split Tail
