I bought a S&W M&P 5.54x39 some years back, and the damned thing has never been reliable. I can clean it as well as I possibly can, breaking the bolt apart, spraying everything, etc, yet it still jams. By jam I mean the bolt locks with a round in it, it will not fire or cycle, and I have to use a rubber mallet to basically hammer the bolt back out. After a good cleaning I got it to run for 90 rounds, but then another time it didn't even run one.
In the past when it does this I have pulled the rear pin, re-cocked the hammer, put the pin back in, and then pulled the trigger again to get the round to discharge. This has worked two times, stopped doing that when the third time I did this the round discharged, but only partially. That time the actual round went into the barrel about 1/2" and unburned powder went everywhere in the action.
This has happened with two types of ammo: Silver Bear, HP zinc plated bi metal casing, and with Barnaul FMJ lacquered steel casing, though not as often with the latter as usually I am at the range where JHP is not allowed.
Any ideas or suggestions? I can't see any visible flaws on any of the pieces, and am just about clueless on what to do next.
Side question: What is bad about using steel casings? How does it hurt the rifle?
