Antenna questions
  • Antenna questions
    I just installed an antenna in the attic and have a couple questions.
    1. Whats the best way to ground the antenna? I put it together but haven't mounted it on the mast yet.
    2. Weird channel issue. I have 2 samsung LCD tv's. The "older" samsung gets all the channels except channel 4 and 33. It is just snow. Which makes no sense. It should say weak signal if it wasn't getting a signal.
    The other Samsung tv has no problems showing channel 4 and 33.
    I plugged the antenna directly to the old tv and same results. I plugged it directly to the new tv and they show. I plugged them both to the antenna and exact same results. works on one and not on the old one.
    This tells me the signal is good. Why won't one of the tv's show 4 and 33?
      You gots to have the 1.21 giggawatts to run the older tv.
        It is possible you might be picking up a couple of low wattage local analog stations...there are some in the DFW metroplex.
