I am looking for info from someone here who has some knowledge about building a variable DC power supply that is powered with regular house hold 110 AC. I am needing a supply that can output from 0 - 150 or 200v and a adjustable current level from 0-5ish amps. Any first hand expierience here????
Building a DC power supply
what is this for?"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
I would guess
Originally posted by CJ View Postwhat is this for?
I'll get you a picture of mine when my phone gets enough charge.Don't worry about what you can't change.
Be honest, even if it hurts.
Originally posted by jyro View Posttruth serum,"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
it's really hard to get 200 volts dc from 120v ac.Don't worry about what you can't change.
Jyro, I see the info tag on that.... what does the 2-25/5-50 mean on the output #'s? I know that it is the measurements depending in if you have 120 or 240 input voltage but I am not used to seeing the ratings written like that. I could do fine with 120vdc output,I would like more though if it was easily available. If it's not like I said 120 will be fine but I need at least that much.Last edited by inline 6; 08-27-2014, 07:35 PM.
PS tag
Originally posted by inline 6 View PostJyro, I see the info tag on that.... what does the 2-25/5-50 mean on the output #'s?
I looked at anodizing aluminum, it only took 30 volts. Does Ti take that much more voltage?Don't worry about what you can't change.
Originally posted by jyro View Post2-25 volts @ 12 amps with 120v supply or 5-50 volts @ 5 amps with 220 supply
-Henry David Thoreau
Originally posted by Mark04 View Post5amp 200VDC power supply is a going to be a beast and definitely something you are not going to build at home. Dangerous as hell as well. Good luck. We use 2 amp regulated bench supplies that can go to 200 VDC at work and they cost close to $700.00.Men have become the tools of their tools.
