Originally posted by abecx
Water Cooling Desktop
Last edited by CJ; 09-17-2012, 06:10 PM."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by abecx View Postfuck you cj you dont know shitLast edited by CJ; 09-17-2012, 06:21 PM."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by abecx View PostBig whoop, i have a 2JZ engine radiator in my setup with a thermaltake 2827J RR spec radiator and F9 Allstar Radiator with an Antec Fata1ity edition fan.
"It will increase the temperature of an average room 10 degrees or more" is insane."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by abecx View PostSo you go to the extreme and blanket statement all of watercooling will increase your ambient room temperature by 10 degrees. The statement is insane even with a CPU and single GPU configuration."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
edit: as a matter of fact I have that exact kit you're looking at - the coolermaster, it's one of the kits I have in a box. It's very tiny, and it's only good for a processor, not a full loop. If you put a GPU on that loop it would be CONSIDERABLY hotter than air cooling. As a matter of fact, a decent copper heatsink would outperform that kit. I would not even recommend it. It's also an aluminum rad and copper block, so it would require special fluid to prevent corrosion.
Originally posted by abecx View PostI have 6 cpus already at 3.4GHz, why would i need to overclock?
Afa heat goes, my three OC'd GPU's put it much more heat than any cpu I've ever seen considering they run in the mid 60-upper 70c range while performing calculations for F@H.
Saved and Texan by the Grace of God, Redneck by choice.
