What's best gear ratio for an 07 Jeep four door with 3.8, 4 speed auto, lift and 35s? My Dad uses it for a daily a pulls a small trailer occasionally. I was think 5.13
Best gear ratio for 07 Jeep
5.13 is the absolute most you want to go with a D30 front axle and it fits 35's very well. If he has the Rubicon model he has D44 front and rear axles and while 5.13 is still a great option 5.38 is on the table at this point as well. With 5.13's and 35's my 08' feels good. I would have went 5.38 if I had the larger front axle though.
I ran 4.88's on 35's and it was perfect at all speeds. I wasn't aware you could fit a 5.13 in a Dana 30 axle. If so, how small is that ring gear and contact surface? I could barely slide a sheet of paper between my 4.88 ring gear and the housing."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by CJ View PostI ran 4.88's on 35's and it was perfect at all speeds. I wasn't aware you could fit a 5.13 in a Dana 30 axle. If so, how small is that ring gear and contact surface? I could barely slide a sheet of paper between my 4.88 ring gear and the housing.
Originally posted by one slow 5.0 View PostFrom what I've been reading online 5.13 is very weak and not good for off-roading. He will hardly take it off road and if he does it will be in the pasture or something like the jeep trails in Silverton Colorado. I'm gonna suggest the 4.88 but will let him make the final decision
Look at this chart..... 5.13 ratio and 35" tire puts you in a perfect range.
Originally posted by inline 6 View PostYou had a TJ though didnt you? I am not sure of the ratio differences in the trans between a TJ and a JK. Also there seemed to be plenty of room in the front axle. It was the rear that was a super tight tolerance."If I asked people what they wanted, they would have said faster horses." - Henry Ford
Originally posted by inline 6 View PostIt was the 5.38 that was offered for the D30 that proved to be too weak. You cant even find them for sale anymore as nobody runs them. Plenty of people running 5.13 in the D30 with no issues. For your fathers use I would definitely get 5.13.
[IMG]http://www.jk-forum.com/forums/attachment.php?
attachmentid=301323&d=1333921001[/IMG]
Just pulling the trailer the rear will do all the work and that ratio in the D44 is no problem. It's not even an issue in the D30 unless you get into some aggressive stuff and are really heavy footed. To be fair that's any ratio in a D30 though. They aren't the strongest axle.
Sent from my SM-N920T using Tapatalk
