Originally posted by 5.0_CJ
The $4000 Jeep TJ project
Whippled '06 by Gearheads - 474rwhp 450rwtq @ 10psi and a few other Borla/Steeda/BMR/CHE/Tokico mods...
Gearheads Dyno Video
Originally posted by Chritaka View PostNice, that's one thing I don't have the skillz for... On the Hanson it was solid bar steel with the center drilled for greasing. You could then just make the arm clamp around it like the Hanson did. I think the JCR is pressed on with a top cap to hold it in place."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by 5.0_CJ View PostSo it's essentially a solid greased shaft that's drilled and tapped at the top for a bolt, and a simple close fitting collar around it? I guess it has a latch on the driverside to keep it from wearing out? I wonder how much one of those bigass 35" tires/wheels weighs? Probably over 100lbs.
Here's a link on tire/wheel weight, you're pretty darn close!
Tire/Wheel WeightWhippled '06 by Gearheads - 474rwhp 450rwtq @ 10psi and a few other Borla/Steeda/BMR/CHE/Tokico mods...
Originally posted by bottlerocket View PostNo, really its the strength of the hinge that it all relies on. Mine uses a trailer spindle."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
The Swing out on my Dad's YJ is home-made and it has held up great for about the last 6 years. Although it has light duty now with a 32" tire on a grocery getter it spent the first 4 years of its life with a 37in sticky mickey on it on my beat up YJ that was known to be jumped, rolled, and just beat to shit all around. One of the mounts was slightly cracked when I swapped the bumper/ tire carrier between the jeeps a few years ago but other than that it has held up great. I will dig around for some pictures of it mounted and try to find some old ones of it being built. Might give you an idea what to use for moving parts.
Originally posted by Treybiz View PostThe Swing out on my Dad's YJ is home-made and it has held up great for about the last 6 years. Although it has light duty now with a 32" tire on a grocery getter it spent the first 4 years of its life with a 37in sticky mickey on it on my beat up YJ that was known to be jumped, rolled, and just beat to shit all around. One of the mounts was slightly cracked when I swapped the bumper/ tire carrier between the jeeps a few years ago but other than that it has held up great. I will dig around for some pictures of it mounted and try to find some old ones of it being built. Might give you an idea what to use for moving parts."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Another
Originally posted by Treybiz View PostDistant Picture for now... I will dig around on my home pc.
http://s256.photobucket.com/albums/h...t=DSC00370.jpg"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by 5.0_CJ View PostYeah this seems to be the general design most all of the mounts use. An A arm with a swing away mount on the passenger side. I'm not too crazy about having my rear view blocked by a giant ass tire, wondering how low you can safely mount one.
With the 32" on there currently it isn't as bad.
Originally posted by Treybiz View PostI have seen a few designs that allow the tire to set pretty low and it was very annoying to have the 37 right in my view. I never ran a top on my YJ so I could only imagine if you had a hard or soft top taking up more of the usable view.
With the 32" on there currently it isn't as bad."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
