I've had this truck since 2001. It's loud enough to make you vomit up on the high end and soo windy down low it may just float a baby. Here's this years upgrades! Pulling about 2000a of current clamping 18k watts and still holding 13v. The Lithium tech is great. 155DB@20hz 158DB@25hz 160.2DB@38hz
Still making noise!
I remember you bringing it to a few gtgs and it used to BOOM back then, I can only imagine how it sounds now...Originally posted by SilverbackLook all you want, she can't find anyone else who treats her as bad as I do, and I keep her self esteem so low, she wouldn't think twice about going anywhere else.
Originally posted by Craizie View PostI'd like to see that in person. God damn!
Originally posted by black50 View Postsure, I dont think death happens until the 180db range...lol
A couple things. First, above 194 dB, it's hard to call it a "sound wave" anymore, as that's where you start getting shockwaves. In a shockwave, the "floor" of the pressure wave is negative (which is why when an explosive shock wave passes over you, you get a lot of overpressure followed by a lot of underpressure.
When discussing damage from shockwaves, there are two things you want to look at: the amount of overpressure, and its duration. The more those increase, the more damage will occur.
As for fatality, it varies widely based on position of the person (side-on vs face-on vs top-on), but the most widely cited values are in the 60-80 psi overpressure range. There is evidence from Army research that repeated exposure to sub-fatal blasts can be fatal, just as repeated exposure to non-injurious blasts can be injurious.
At lower overpressures (even as low as 5 psi overpressure) you can start seeing things like eardrum rupture. Slightly higher you get GI tract hemorrhaging and lung lesions. In small amounts, these are subclinical, but in larger amounts, it can quickly cause real problems.
For further reading, the term in literature you're looking for is "blast injury". A lot of the publication on the subject comes from the 40s-60s, especially from the American atomic tests.
For reference, the sound pressure of a 30.06 is 1.05 psi.
3dB is two times the sound energy
6dB is two times the sound effect
10dB is percieved as twice as loud193 dB = 1019 times the reference point
100 dB = 1010 times the reference point
50 dB = 100,000 times the reference point
10 dB = 10 times the reference point198dB is the loudest sound that can be produced. Since sound is the densification and thinning of air, or really air molecules, 198dB is the loudest sound that can be produced before the thinnest part is nothing but vacuum. Yes, air pressure can be bigger, e.g with an explosion, but that is not really the same thing as a sound, and would not be percieved as sound but that is of course a question of definition.
Also, dB is a reference scale. Meaning 0 dB is the same as the reference, not just "nothing". The most used dB scale is the "Sound Pressure Level" or SPL where 0 dB SPL equals 20 mikro pascal.
150 decibels is usually considered enough to burst your eardrums, but the threshold for death is usually pegged at around 185-200 dB. A passenger car driving by at 25 feet is about 60 dB, being next to a jackhammer or lawn mower is around 100 dB, a nearby chainsaw is 120 dB. Generally, 150 dB (eardrum rupture) is only achieved if you stand really close to a jet aircraft during take-off or you’re near an explosive blast.
If you actually wanted to intentionally kill someone with a sonic weapon, there isn’t a whole lot of research on how you would actually go about doing it. The general consensus is that a loud enough sound could cause an air embolism in your lungs, which then travels to your heart and kills you. Alternatively, your lungs might simply burst from the increased air pressure. (Acoustic energy is just waves of varying sound pressure; the higher the energy, the higher the pressure, the louder the sound.) In some cases, where there’s some kind of underlying physical weakness, loud sounds might cause a seizure or heart attack — but there’s very little evidence to suggest this.
Copyright © 2025 MH Sub I, LLC dba vBulletin. All rights reserved.
