No, if I were to spend any kind of significant $$$ on a tool for fabrication it would be a lathe and end mill attachments. Much more can be accomplished machining from brass and aluminum
I confirmed my wheel sleeves earlier today, not sure how long it will take to receive them. They will be ~20x9 up front and 20x12 in the back. I had originally planned on 18's but typically with these kits, bigger looks more correct. I undoubtedly caused myself more work in the way of mini tubs and re-fabbing the back half of the chassis. Time will tell. Here is a teaser pic of some wheels the machinist did for another 1/12 Camaro. Modeled after Fikse wheels
Originally posted by LeahBest balls I've had in my mouth in a while.
Wheel sleeves should be here by mid next week. I order 3D prints of my wheel centers and enough brake parts to finish up the brakes on the front end. Once all of that arrives I can put together a front wheel "assembly" and start working on the front suspension.Originally posted by LeahBest balls I've had in my mouth in a while.
Well, the wheel sleeves showed up today. Much to my dismay, they are incorrect. The centers are designed to be front mount, like this wheel:
They sleeves are designed to be rear mounted, which would require re-designing the centers. The other thing I never liked with the machined aluminum model wheels is the way they are stepped. I am not sure if this is a limitation of the equipment, machinist, or a result of the small scale.
What I got:
What it should have looked like, with a little less offset of course:
Well, the wheels are going back today. I talked with the machinist and hopefully he is able to accomodate my resquest. The lip machined on the inside of the wheel for the center to be mounted to is going to be removed. In place of that he is going to machine me a ring that will serve as the mounting point for the center, that way I can adjust the backspacing as needed. If any of you here are a machinist please chime in! I think I can "set" the ring with loctite. Also, what I have asked for is for the overall diameter to be turned down, essentially removing the outer step so that I am left with a more realistic looking wheel.
Everything outside of the black mark would be removed, leaving me a single flare and a small lip to imulate the tire mounting lip.Originally posted by LeahBest balls I've had in my mouth in a while.
Originally posted by silverhatch View PostSir I think you have a problem and the first step is to admit it.Originally posted by LeahBest balls I've had in my mouth in a while.
Just got done talking with the machinist and he is confident he can accomodate my requests. If he can, I should have almost exactly what I have been searching for, for the last 4-5 years. So hopefully in another month, I will have my motivation!Originally posted by LeahBest balls I've had in my mouth in a while.
