O Ok, this shouldn't be this hard, but it has me already scratching my head. Last time I did this with my boat a few years ago I made the mistake of mounting all the lights, then trying to wire everything.
This time all I've done is run 25' of cable along the bed of the trailer, and temporarily hooked it up to my flat four connector which hooks to my truck.
Now, I'm installing LED running lights on the rear of my trailer, in addition to your normal tail lights, it's actually an led light bar. I'd like it to act as a stop/turn in addition to running lights, not sure if it will work that way.
Here is what's stumping me. The four wires are all labeled as you can see. But when I turn on my parking lights only the white wire (labeled ground) lights up with my light tester. Shouldn't the brown wire labeled TAIL LIGHTS be lighting up when I hit it with the tester?
Also, my LED light bar has a green, white and black wire. Which wire connects to which wire of my four off my main set of four wires? Here are some pics, I'd just hook up and test different combinations but I fear shorting something out.
On my clearance lights won't black go to tail and white to ground? Guess this is what I get buying all this for ten bucks from a guy down the street without any instructions.
