Gt500 vs z06... Blown motor.
  • Gt500 vs z06... Blown motor.
    [ame]http://www.youtube.com/watch?v=L6gOACzKEIs&sns=em[/ame]
    Its under warranty right?!
    That sucks! Wonder what failed?
      That's gonna leave a big dent in the pocket book...ouch!
        Most will argue the driver did.
          That's what happens when you do back to back to back pulls down the hwy with a blower car. Too much heat and it will eat a couple pistons..
            This.
            Heat soak is a bitch!
              I dont think that's it. They test the GT500 on the Ring, where the back straight is several miles long at WOT. Sure it will heak soak and run hot, but stock tune it should at least pull lots of timing out.
              I think either the tune was off, or #8 overheated and let go.
                I'd guess shitty tune.
                  Yea on a stock tune. Car let go In a big way though!! I have also seen some aggressive tuners set the minimum spark tables pretty high where it con only pull a few degrees.
                    If he can afford that car he should be able to afford a new motor...
                    Originally posted by Da Prez
                      Time to upgrade!!
                        I thought it was a head gasket from all the white smoke but once he slowed there were flames coming out of the pipes, wonder if that was oil not water?
                          They don't call them the LSWin motor for nothing
                          GOD BLESS TEXAS
                          August Landscaping
                          214-779-7278
                          Seb's high class.
                          He'll mow your grass.
                          He'll kick your ass.
                          He'll piss in a glass!
                            That was A LOT of smoke...I'd say much more than just a head gasket, I'm going to say a hard busted cylinder....especially since it appeared he was starting up an oil fire there at the very end.
                            Either way...damn!
                            70' Chevelle RagTop
                            (Forever Under Construction)
                              Looks like it may have kicked a rod.
