Apparently oil starvation/bearing failure at the 1200' mark at 6800 RPM does damage to a LOT of stuff.
Up to this point i have found that pretty much the entire bottom end is junk. I got one head off and found that all 8 valves in that head had touched a piston hard enough to at least mark each valve relief. #4 rod is the one that disintegrated, #1 exhaust valve is bent at about a 30 degree angle. I feel pretty fortunate now that more stuff didn't get damaged. Pretty sure all 8 of the valves in that head are bent, but not a one of the pushrods are bent. Smith Brothers 3/8 .120 sidewall ftw there.
Anyways, here are some pics of the carnage. Looks like I am starting over this winter. Oh well, it was time for an Iron Eagle block, F2 and shorter stroke setup anyhow.
