Originally posted by Blackpony
Notice that the neg side goes thru the pressure switch just ground it on the outside to the tranny case and run 12 volts to the other side. Pretty simple.
If your tranny does not have the electrical connector on the drivers side it is not a TH350C (Lock Up version)
If you want a 4L60E the you will need that turned back on in your tune. Bring me a core and I can fix you up. Prices depend on what you want. Stock rebuild with normal updates start at 650.00 Converter should be around $500-$600. Or you you could get the stock re-stalled locally for around $200 or so. I would expect around 2000 stall from a re-stalled stock converter.
