the first pic... the 3/4 inch corrugated pipe, looks as tho the block above it has no support
Critique my Retaining Wall
Originally posted by slow06 View PostThat spot where you drop down two layers at the same time is what sticks out to me. Even that out and I think you improve the look significantly.
Originally posted by forbes View Postthe pipe on the left is going to be a fail point. notice how the joint isnt supported above. it will cause a domino effect. at least that is the way the picture looks
In all seriousness, he's probably right. What is this corner resting on?
"A government big enough to give you everything you want, is strong enough to take everything you have."
-Gerald Ford/Thomas Jefferson
Originally posted by slow06 View PostYou mean this little guy? I wouldn't worry about that little guy.
GOD BLESS TEXAS
August Landscaping
214-779-7278
Seb's high class.
He'll mow your grass.
He'll kick your ass.
He'll piss in a glass!
Originally posted by SEB View PostIt might be the picture, The base is all concrete on that corner. If you look closely that corner of that wall & back behind the brick is all concreteOriginally posted by BradMBut, just like condoms and women's rights, I don't believe in them.Originally posted by LeahIn other news: Brent's meat melts in your mouth.
Originally posted by Ratt View PostWeep holes red to be every 4-6 feet on the long side anywhere it's over two feet tall, and on the tall side it needs to be every 2-4 feet (probably closer to 2). Looks great otherwise, good work man.
Thus my thread & any suggestions to help relieve the water from this corner when it rains hard in SpringGOD BLESS TEXAS
August Landscaping
214-779-7278
Seb's high class.
Originally posted by bcoop View PostWhat they are saying is that the block on top of the left drain, does not appear to be supported by anything other than the drain. It's not overlapped on to another brick, or doesn't appear that way anyways.GOD BLESS TEXAS
August Landscaping
214-779-7278
Seb's high class.
Originally posted by SEB View PostOK now I see their point! Well better to find out now then later! Looks like im gonna have to rebuild that cornerOriginally posted by MR EDDU defend him who use's racial slurs like hes drinking water.
For the record though, it generally looks good. I did a fairly long retaining wall about 4' high once. The french drain worked okay, but any extra drainage you can provide does help. After awhile, I noticed it seeping through the wall anyway.Originally posted by MR EDDU defend him who use's racial slurs like hes drinking water.
